Hi!
I’m struggling to find a solution to setup correctly a script to control the parameter of my music event in FMOD.
What I want to do is very simple: I have a looping track that should transition to an ending when the game is over (i.e. the player health is =< 0). The event is named “BackgroundMusic” ad I have a “currentHealth” parameter set up with min-max values 0.00 - 100.00 (max health in game). A transition region to the ending is set up to be active under a parameter = 0.00 condition.
Now, to do this in Unity, I’m not sure how to control the parameter with the script.
I tried to use a script similar to the one described in the FMOD Unity integration documentation with no success.
I attached this code to an object in the game (the game has a PlayerHealth script):
using UnityEngine;
using System.Collections;
public class MusicManager : MonoBehaviour
public PlayerHealth playerHealth;
FMOD.Studio.EventInstance backgroundMusic;
FMOD.Studio.ParameterInstance currentHealth;
// Use this for initialization
void Start ()
backgroundMusic = FMOD_StudioSystem.instance.GetEvent ("event:/Music/BackgroundMusic");
backgroundMusic.start ();
backgroundMusic.getParameter (“xxx", out xxx);
void Update ()
currentHealth.setValue (playerHealth.currentHealth);
I don’t know what to fill the xxx with, trying out different things the only thing I managed to achieve was for the music to play from the ending (i.e. FMOD doesn’t receive the parameter update and set it to 0 by default).
As you may have noticed, I’m not a programmer and I’m really new to this.
How do I get the player health information to feed FMOD so that I can control the parameters?
The other thing I thought was that, rather than attach it to an object, I could implement the music right in the PlayerHealth script, but all my attempts lead to a failure.
Here’s the PlayerHealth script (the other FMOD objects you see in this are other player sounds that I manage to implement correctly):
using UnityEngine;
using UnityEngine.UI;
public class PlayerHealth : MonoBehaviour
public int startingHealth = 100;
public int currentHealth;
public Slider healthSlider;
public Image damageImage;
public float flashSpeed = 5f;
public Color flashColour = new Color(1f, 0f, 0f, 0.1f);
Animator anim;
PlayerMovement playerMovement;
PlayerShooting playerShooting;
bool isDead;
bool damaged;
void Awake ()
anim = GetComponent <Animator> ();
playerMovement = GetComponent <PlayerMovement> ();
playerShooting = GetComponentInChildren <PlayerShooting> ();
currentHealth = startingHealth;
void Update ()
if(damaged)
damageImage.color = flashColour;
else
damageImage.color = Color.Lerp (damageImage.color, Color.clear, flashSpeed * Time.deltaTime);
damaged = false;
public void TakeDamage (int amount)
damaged = true;
currentHealth -= amount;
healthSlider.value = currentHealth;
FMOD_StudioSystem.instance.PlayOneShot ("event:/Player Sounds/Player Hurt", new Vector3(0,0,0));
if(currentHealth <= 0 && !isDead)
Death ();
void Death ()
isDead = true;
playerShooting.DisableEffects ();
anim.SetTrigger ("Die");
FMOD_StudioSystem.instance.PlayOneShot ("event:/Player Sounds/Player Death", new Vector3(0,0,0));
playerMovement.enabled = false;
playerShooting.enabled = false;
public void RestartLevel ()
Application.LoadLevel (Application.loadedLevel);
If anyone could give me an help that would be greatly appreciated!
