Creating empty events from GUIDs.txt
Help me create a script for Unity that will create events that are in GUIDs.txt. That is, the script will create empty events, but they will have the same path, name and GUID as in the .txt file. I also have a script that is used to create events through Unity (I took it from the official plugin)
here he is:
            var folders = eventPath.Split(new char[] { '/' }, StringSplitOptions.RemoveEmptyEntries);
            string folderGuid = GetScriptOutput("studio.project.workspace.masterEventFolder.id;");
            const string getFolderGuidFunc =
                @"function(parentGuid, folderName) {
                    folderGuid = """";
                    studio.project.lookup(parentGuid).items.forEach(function(val) {
                        folderGuid = val.isOfType(""EventFolder"") && val.name == folderName ? val.id : folderGuid;
                    if (folderGuid == """")
                        var newFolder = studio.project.create(""EventFolder"");
                        newFolder.name = folderName;
                        newFolder.folder = studio.project.lookup(parentGuid);
                        folderGuid = newFolder.id;
                    return folderGuid;
            for (int i = 0; i < folders.Length; i++)
                string parentGuid = folderGuid;
                folderGuid = GetScriptOutput(string.Format("({0})(\"{1}\", \"{2}\")", getFolderGuidFunc, parentGuid, folders[i]));
            if (CheckForNameConflict(folderGuid, eventName))
                EditorUtility.DisplayDialog("Name Conflict", string.Format("The event {0} already exists under {1}", eventName, eventPath), "OK");
                return null;
            const string createEventFunc =
                @"function(eventName, folderGuid) {
                    event = studio.project.create(""Event"");
                    event.note = ""Placeholder created via Unity"";
                    event.name = eventName;
                    event.folder = studio.project.lookup(folderGuid);
                    track = studio.project.create(""GroupTrack"");
                    track.mixerGroup.output = event.mixer.masterBus;
                    track.mixerGroup.name = ""Audio 1"";
                    event.relationships.groupTracks.add(track);
                    tag = studio.project.create(""Tag"");
                    tag.name = ""placeholder"";
                    tag.folder = studio.project.workspace.masterTagFolder;
                    event.relationships.tags.add(tag);
                    return event.id;
            string eventGuid = GetScriptOutput(string.Format("({0})(\"{1}\", \"{2}\")", createEventFunc, eventName, folderGuid));
            return eventGuid;
Unfortunately, while it is possible to create the folders and events based on an external list, it’s not possible to specify the GUIDs of entities in Studio.
