In ‘untiy’, there is a skill that reduces the frame rate of the image and slows down the audio. How to solve the problem of audio not receiving the image or motion being slowed down? Is this a problem that FMOD can solve, or does it require programming to solve.
The Slow-mo snapshot that is in our Studio example may be what you are looking for:
It downshifts the pitch of the group bus when played. Let me know if this is the behaviour you are looking for.
The example project can be found here: "C:\Users\XXX\Documents\FMOD Studio\examples\Examples.fspro"
Hope this helps
Hello, may I ask which version of FMOD is the example you mentioned?
I tried it and the effect was still good. Thank you very much
