Hi everyone!
I’m having an issue that I can’t seem to solve, and so far seems like some kind of bug, unless I’m overlooking something obvious.
I have a couple of sound effects set up as 2D events in FMOD using the built-in Distance parameter, so they should get louder when the player/camera approaches. I’m doing this by modulating the Volume over distance. The Studio Listener is attached to my camera and I’m playing the SFX using
FMODUnity.RuntimeManager.PlayOneShot("SFXname", transform.position);
This used to work perfectly fine, but now those events don’t play at all. Every other event, that isn’t using the distance parameter works fine. Events that have the Distance-paremeter attached work as well, as long as there’s no kind of modulation done over Distance. As soon as I add a point to any modulation curve, the sounds do not get played in the game - even if the curve doesn’t actually modulate anything (i.E. keeping dB at 0.00, but there’s a point on the curve).
A suspicion I’m having is that the sound’s aren’t played at the correct position, but the code is definitely correct, everything was working fine that way until, I think, I updated to FMOD 2.0, now I can’t seem to make any use of the built-in Distance parameter at all (however I’m not exactly sure the Update is what caused the issue. I only noticed it today and updated a few days ago). I also re-imported the Unity package to no success.
I’m using Unity version 2018.3.5f1 Personal.
Anybody got an idea what could be the issue?
