As I looked on your responses in different topics, there is no official support for 7.1.4 system in UE4 plugin.
However, I’d like to ask:
Is it ok if I add the option to use 7.1.4 in the plugin myself?
What I mean is that I’ve looked into the plugin code and I’ve noticed that there is FMOD_SPEAKERMODE available for that:
typedef enum FMOD_SPEAKERMODE
FMOD_SPEAKERMODE_DEFAULT,
FMOD_SPEAKERMODE_RAW,
FMOD_SPEAKERMODE_MONO,
FMOD_SPEAKERMODE_STEREO,
FMOD_SPEAKERMODE_QUAD,
FMOD_SPEAKERMODE_SURROUND,
FMOD_SPEAKERMODE_5POINT1,
FMOD_SPEAKERMODE_7POINT1,
FMOD_SPEAKERMODE_7POINT1POINT4, //HERE
FMOD_SPEAKERMODE_MAX,
FMOD_SPEAKERMODE_FORCEINT = 65536
} FMOD_SPEAKERMODE;
So I changed FMODSettings.h and FMODSettings.generated.h to include it:
UENUM()
namespace EFMODSpeakerMode
enum Type
// The speakers are stereo
Stereo,
// 5.1 speaker setup
Surround_5_1,
// 7.1 speaker setup
Surround_7_1,
Surround_7_1_4 //<----HERE
#define FOREACH_ENUM_EFMODSPEAKERMODE(op) \
op(EFMODSpeakerMode::Stereo) \
op(EFMODSpeakerMode::Surround_5_1) \
op(EFMODSpeakerMode::Surround_7_1) \
op(EFMODSpeakerMode::Surround_7_1_4) //<----HERE
And also put the speaker mode to be changed in ConvertSpeakerMode
inline FMOD_SPEAKERMODE ConvertSpeakerMode(EFMODSpeakerMode::Type Mode)
switch (Mode)
case EFMODSpeakerMode::Stereo:
return FMOD_SPEAKERMODE_STEREO;
case EFMODSpeakerMode::Surround_5_1:
return FMOD_SPEAKERMODE_5POINT1;
case EFMODSpeakerMode::Surround_7_1:
return FMOD_SPEAKERMODE_7POINT1;
case EFMODSpeakerMode::Surround_7_1_4: //<----HERE
return FMOD_SPEAKERMODE_7POINT1POINT4;
default:
check(0);
return FMOD_SPEAKERMODE_DEFAULT;
Thanks to that, I was able to change the option in the project settings:
I tested it for a short period of time and nothing exploded.
Do you think it is ok to do it this way, enabling the output format in the code like this? You probably need testing for this feature before it is officially supported, but I’d like to know if you think this is a good way to do it or should I wait for official support.
