Event not showing in event emitter
I installed FMOD Studio ver 2.03.07 and Unity 2022.3.61f1 and installed the FMOD package for Unity via the Asset store.
After using the integration wizard for FMOD and having all conditions checked as green, I loaded FMOD Studio and created a new project. Then, I created a new event, added a timeline sheet and placed an audio clip in the timeline. Then, I assigned the event to the master bank, built the project and saved it.
When I add and event emitter component to an empty game object in Unity and hit the search button, there are not any events listed.
Are you seeing any errors or warnings in the output window?
When you build the banks in FMOD Studio, do you also see the popup in Unity about the FMOD Banks being refreshed?
I was having the same problem.
Turns out I was using the wrong FMOD for Unity version. From the asset store I had downloaded “FMOD for Unity (2.02)” when in reality I am using Fmod 2.03 and so I needed to download “FMOD for Unity (2.03)”.
Once I downloaded and imported the correct Fmod asset, my event list was properly populated with sounds from Fmod.
