Events Preview Work but No Sound at Runtime
I’ve been trying to set up FMOD with Unity on my own, then spent quite a while debugging it with ChatGPT, but we’re going in circles and can’t find the issue. I’m probably missing something basic.
Here is my setup and the problem:
Setup:
  • Unity + FMOD Unity Integration (version 2.03.12)
  • FMOD Studio project (same version)
  • Integration wizard completed, project correctly linked
  • Banks built successfully (Master.bank + Master.strings.bank in Build/Desktop)
  • Load Banks = All
  • FMOD Listener on main camera
  • Unity Audio disabled
  • Very simple FMOD project (a few events, no parameters, no complex routing)
  • Events have audio on timeline and are routed directly to Master Bus (0 dB)
Problem:
  • No sound at all in Play Mode
  • Events preview correctly in the FMOD Event Browser inside Unity
Observed behavior:
  • FMOD overlay shows:
    RMS = -80 dB
    Channels total = 1
    Channels real = 0
  • FMOD logs show:
    • system initializes correctly
    • audio device is fine (CoreAudio)
    • banks are loaded
    • samples are loaded (createSound)
    • samples are immediately released (SoundI::release)
    • no errors or warnings
    • no indication that any EventInstance is actually started
What I tested:
  • EventEmitter with different triggers
  • RuntimeManager.PlayOneShot(“event:/Pickup”)
  • RuntimeManager.CreateInstance + start() + release()
  • Copied exact event path from Event Browser
  • Verified event is in Master Bank
  • Created new simple test event (same result)
  • Checked routing, volume, no mute, no automation
  • Tried loading sample data manually
  • Verified banks and paths
  • FMOD Listener is active
  • No console errors at all
Conclusion:
FMOD seems to initialize and load everything correctly, but no event is actually played at runtime (channels real stays at 0). It feels like events are not being triggered or resolved properly, but without any error.
If anyone has seen this behavior before or has an idea of what basic setup issue could cause this, I’d really appreciate the help !
Thank you for sharing the detailed information.
Unfortunately, I was not able to reproduce the issue on my end. Could you please share the Unity version you are using?
You may already checked this, but just to double check, does anything in the following troubleshooting section help?
27.2 Some events aren’t audible at runtime.
If not, could you please try deleting the entire FMOD folder from your project’s Plugins folder, then reinstalling the FMOD for Unity integration to see whether that helps?
Hey ! Thank you for the fast answer. I’m on Unity 6.3 (6000.3.9f1).
Tried the troubleshooting section but nothing solved the problem.
Tried to delete the folder and reinstall the plugin but nothing better. First time I tried linking the .fspro, then I tried to only point to the bank file, but still doesn’t work.
For testing purposes I droped an event in the scene from the EventBrowser, and set it to Object Start. No sound when I run the game (as you can see in the screenshot), though I can clearly hear it and the the level modulate in the EventBrowser.
I feel like it’s either a bug or absolutely basic thing that I completely missed out.
Here are the FMOD settings if that helps. Also, in Unity’s Assets folder, I have no “Streaming Assets” folder existing, is that normal ?
Thank you for the screenshots and additional details.
You may have already checked this, but just want to double check something simple here in case it’s being overlooked, since I was still not able to reproduce the issue on my end, could you please check whether Unity is muted in the Game view?
Specifically, the mute toggle here:
Also, would it be possible to share a screenshot of your event in FMOD Studio, as well as the Master Bus routing? Just to double check that everything is set up correctly on that side.
omg it was simple as that, I didn’t even know Unity had this feature. It was the mute button, thanks a lot for your help !
