My Fmod had an unexpected exit when copying and pasting nested event tracks. But dragging nested events directly onto tracks does not occur. My version is 2.0004
Thanks for the bug report. I haven’t been able to reproduce this issue yet, so I suspect I’m doing something differently to you.
When you say “nested event tracks,” do you mean “tracks that contain event instruments,” “event instruments,” or "the tracks found in nested events?
What event are you pasting into? The same event you’re copying from, a different event, or the nested event?
What part of the event are you pasting into, and how are you giving the paste command? Are you using the keyboard shortcut, the Edit menu item, or a context menu item? Do you target the track head, the track body, or some other part of the event?
