Hello I play Orbus reborn and the fmod audio is terrible is it something on your end or orbus end? People have to keep relogging to hear each other at least 10 times an hour.
FMOD can play streaming audio if given an audio stream, but doesn’t have anything to do with network connectivity or sending those audio streams over the internet.
Given that your problem can be solved by relogging in, I suspect it’s probably a networking/connectivity issue, and therefore unlikely to be caused by FMOD.
In any case, you should probably report this issue to the developers of Orbus, who should have access to the code of Orbus and so will be able to investigate it.
