Hello! When I set the object for attenuation in Fmod studio listener in Unity, for some reason attenuations still work from the camera. Is there something else I need to add or what could be the problem?
What version of the FMOD integration are you using?
Testing 2.02.18 in Unity 2022.3.8f1 I was unable to reproduce the error.
How many listeners do you have in the scene?
2.02.19, one listener
I can’t provide the project…Also we are using Steam Audio in the project, could this affect it?
Thank you for the information.
Steam Audio will not use the attenuation object set on our listener as it is an external plugin. Is it possible to use our spatializer as that will work as expected?
