Hi there.
I’m trying the global scope parameter on a music track.
I tried to set the parameter value in UE4 4.23 with the last Fmod version, in Blueprint via set parameter node, but it doesn’t do anything. Any idea why?
Are you using the Set Global Parameter By Name node?
@alexzzen there is a set Global parameter node? I can’t find it. I’m using the classic set parameter node.
yeah there should be one I think:
Try to deselect the “context sensitive” checkbox when right clicking on a blueprint to search for a node, sometimes it hides some nodes for me.
Wow thanks!
