Unity 2021.3.15f1 and FMOD for Unity 2.02.11. This is a new project with no prior FMOD integration.
Thank you for the additional information- I have only been able to reproduce this error in 2.02.11 when setting the Source Type to “Multiple Platform Build” and setting the Build Path to the “Desktop” subdirectory, but the error makes sense in that context.
If you do come across this issue again in future, can you please note down what your Source Type and Build Path are and share them here?
This worked for me, but I had to keep the Load Banks settings on Specified.
This should have been fixed in the 2.02.08 version of the FMOD Unity integration. Can you please tell me what version your FMOD integration is, and send me a screenshot of the FMOD Unity Settings page?
Thanks for the additional information. That certainly looks like a regular FMOD Unity setup. Can you please tick the Enable API Error Logging option, set the Logging Level to “Log”, and tell me what errors you are getting with Load Banks set to “All”?
