Hello, im working on sound mods for Assetto Corsa.
I want to have some sounds to be always centered (coming from both speakers all the time)
The other sounds should still be 360 degree sounds.
how the spatializer or 3D panner can be adjusted?
Because right now, no matter which setting in the 3D panner i change, the sound is still 360 degrees.
Or ask in a different way: How can u make a sound to be played, depending on where the car hits the wall? (car hits with the right side = sound comes from the right speaker)
How are those scripts made? If i knew how it works, i could use the knowledge to change the script, to make the sound to come from both speakers all the time.
