I tried to load a MIDI file using createSound or createStream but it returns FMOD_ERR_PLUGIN_RESOURCE. I don’t understand what it means. So is there any example code to play MIDI file easily using a single API to load and a single API to play? If you insist a common user take a decade to be an expert before using FMOD to play MIDI file, can you show me a learning path? Thanks.
Related topics
| Topic | Replies | Views | Activity | |
| FMOD play_stream example | 2 | 4298 | August 6, 2014 | |
| How to load MIDI file and retrieve played notes | 1 | 3880 | November 20, 2017 | |
| Playing mid without sound~~~ | 3 | 367 | April 15, 2019 | |
| New to Fmod Studio API, basic minimalistic guide/tutorial/example for mp3 playback needed. | 2 | 452 | March 25, 2018 | |
| stuck on the simplest possible thing | 4 | 4605 | November 10, 2015 |
