Since i don’t know if it’s Unity or Fmod, i have send a bug repport to Unity case 1338413
Here a recap about my problem :
Configuration :
Ubuntu 20.04
Fmod 2.01.07 Verified (tried also on 2.02)
Unity 2019.3.9f1 (tried also on 2021.1 latest release)
I tried a blank project with just Fmod to see if it’s working on Linux, normally it would.
But a stack overflow exception and/or the “Fallback handler could not load library /home/marc-cerutti/Unity/2020.3.9f1/Editor/Data/Mono/lib/libAssets/Plugins/FMOD/lib/linux/x86_64/libfmodstudioL.so” display, depending if it’s in editor or in build.
After quiting play mode it freeze the Unity Editor and the processus must be killed to restart.
Strangely, build to linux_64 in release mode work.
We can also listen the sound in the fmod event browser.
The Fmod project is made on Windows, and it work from Windows Unity editor.
I would to know also if there is a Fmod version and Unity associated compatible with my case.
Thanks for the reading.
