I have some problems with FMOD_Studio_System_LoadBankFile. I’m trying to use the C API on my Mac (10.8.5), since I didn’t get the linker to work on my PC (using MinGW).
The problem is that when I call FMOD_Studio_System_LoadBankFile it just hangs indefinitely. I’ve tried passing the flag FMOD_STUDIO_LOAD_BANK_NONBLOCKING to the call and then looped polling the status with FMOD_Studio_Bank_GetLoadingState(). That always returned the value 2: “loading in progress” (FMOD_STUDIO_LOADING_STATE_LOADING).
I’m a FMOD beginner so I may have missed something basic. I did a Build from within FMOD Studio and put the “Master Bank.bank” where my program could find it. I also copied the “Master Bank.strings.bank” file to this same directory. Do I need to put something else here?
Do the bank files include the audio data itself, or do I have to move the wav files to somewhere?
I’m compiling using clang with C++ 11.
I’ve gotten the lowlevel API to work fine, both on Mac OS (clang, C++ 11) and Windows (with MinGW, C++ 11, using the C API to avoid name mangling problems with the Visual Studio dll). But I’m having much more problems with the Studio API it seems.
I really want to get this working for a game that me and a few friends are working on :).
It sounds like you have a static initialisation order issue. Is the sound_system singleton object defined as a static object, rather than being created inside the sound_system::get_instance() function? If so, it will be initialised at static initialisation time. Since the order in which static objects are initialised is undefined, your sound_system singleton may be getting initialised before static objects inside FMOD, causing all sorts of issues.
You probably need to call FMOD_Studio_System_Update to flush the command buffer after calling FMOD_Studio_System_LoadBankFile. By default, the FMOD Studio API runs in asynchronous mode, where all commands are processed by a separate update thread. In this mode, commands you issue are stored in a command buffer, which is only flushed when you call FMOD_Studio_System_Update. It sounds like your issue is occuring because the command buffer never gets flushed, so the load command never reaches the update thread.
Alternatively, you could just call FMOD_Studio_System_LoadBankFile with FMOD_STUDIO_LOAD_BANK_NORMAL instead of FMOD_STUDIO_LOAD_BANK_NONBLOCKING.
Hi, thanks for your quick answer! You seem to got a surprising high level of support here :).
The two things you mention I have already tried. The update call doesn’t seem to make any difference, and the load call with the normal synchronous load mode just blocks indefinitely. Any other ideas?
Hmm, it sounds like something weird is going on. Can you try modifying the simple_event example (from the FMOD Studio Programmer’s API package) to load your bank?
Also, I missed this question before, sorry:
The bank files include the audio data, so all you need for this example is “Master Bank.bank”.
OK, I can try that. It’s strange though, the exact same code that hanged on Mac works perfectly fine on Windows. Also, I want to stick to the C API and the sample uses the C++ API.
Do you think it can have anything to do with the fact that I’m using Clang instead of gcc?
OK, so I managed to circumvent the error. In my test code, I was doing everything from the constructor of a singleton object (the sound system object). When I move the code to a separate function and call that at a later point it seems to work.
This really confuses me though. I couldn’t reproduce the issue in an isolated program. It only happens in my game, which uses some extra libraries: SFML 2.1, LuaJIT 2.0.3, Boost. And also, as mentioned, it works fine on Windows.
Do you have any theories as to why it hangs when I do work in the constructor? Am I missing something obvious?
Basically the situation is:
sound_system::sound_system()
initialize(); // init sound system and load some test banks
sound::sound_system* s = &sound::sound_system::get_instance();
The above hangs in the call to load a bank.
s->initialize();
