Hello, the sound effect event has been configured in until, but the folder name has been changed in fmod, and the event path does not match. May I ask how to make the event name in until match the file name modified in fmod.
Try the FMOD menu at the top of the Unity Editor, FMOD/UpdateEventReference
你好,想问一下你说的是哪一个版本的fmod集成,我的是2.01版本,没有找到这个选项。
Unity编辑器上面的菜单栏加了Fmod插件之后,就有一栏是FMOD,点开然后里面就有个Update Event Reference,不知道你遇到的问题是不是这个能解决的
好的 感谢两位的回复
