Kinda of a weird one - but is there a way I can use multiple listeners for a single player game? E.g. if you can play a game inside a game and want to have a listener inside the “meta game” that only relates to a group of sounds put into that game… Hoping that question made sense ![]()
There’s a couple of ways of handling this, depending on how your game is set up:
Studio::System::setListenerWeightcan be used to adjust how much a specific listener affects the mix, essentially allowing you to fade between or disable specific listeners if you have multiple.- With multiple listeners affecting the mix at once, you can use
Studio::EventInstance::setListenerMaskto specify which listeners are taken into account for a given event instance’s behaviour. - You could also resolve this in your own code when the player moves to the meta game, for example by disabling the non-meta game listener and “swapping” to the meta game listener, or adjusting the attributes of the existing listener to suit the needs of the meta game, etc.
