I’m a music/audio guy and I’m just starting out with FMOD, and I could use a little help with the basics of implementation. I created a simple sound event in FMOD and I’m trying to get it to work with the simple event project that’s included with the API (simple_event.xcodeproj). I only have a little basic programming experience, but looking at the code for this project I have at least a general understanding of what’s going on. Here’s what I’ve done to try to get the sound to work in this project:
- Created the sound event in FMOD, ran the build and exported GUIDs.
- Overwrote the Master Bank.bank and Master Bank.bank.strings files that came with the sample project with the ones from my build.
- Copied the audio file for the event into the project’s Media folder.
- Commented out sections of the code that refer to the looping ambience and surge sounds–I’m just focusing on the one shot pulse at the moment.
- Replaced the path and GUID in the sample code with those from my GUID.txt file.
The result is that the program complies successfully, but when I click the button to trigger the sound, I get the following error:
I tried changing the GUID of the other two sounds in the project as well and it always results in this error message. I’m guessing that I’m missing a basic step, but I haven’t been able to figure out what. Can anyone help me figure out what’s going on? Here’s my code:
Simple Event Example
Copyright (c), Firelight Technologies Pty, Ltd 2012-2013.
This example demonstrates the various ways of playing an event. Controlling event
playback using a persistent instance versus fire and forget.
#include "fmod_studio.hpp"
#include "fmod.hpp"
#include "common.h"
int FMOD_Main()
void *extraDriverData = 0;
Common_Init(&extraDriverData);
FMOD::Studio::System system;
ERRCHECK( FMOD::Studio::System::create(&system) );
ERRCHECK( system.initialize(32, FMOD_STUDIO_INIT_NORMAL, FMOD_INIT_NORMAL, extraDriverData) );
FMOD::Studio::Bank masterBank;
ERRCHECK( system.loadBank(Common_MediaPath("Master Bank.bank"), &masterBank) );
FMOD::Studio::Bank stringsBank;
ERRCHECK( system.loadBank(Common_MediaPath("Master Bank.bank.strings"), &stringsBank) );
// Get the Looping Ambience event
/*FMOD::Studio::ID loopingAmbienceID = {0};
ERRCHECK( FMOD::Studio::parseID("{be4d0587-d91a-42e3-8286-2590da98246e}", &loopingAmbienceID) );
FMOD::Studio::EventDescription loopingAmbienceDescription;
ERRCHECK( system.getEvent(&loopingAmbienceID, FMOD_STUDIO_LOAD_BEGIN_NOW, &loopingAmbienceDescription) );
FMOD::Studio::EventInstance loopingAmbienceInstance;
ERRCHECK( loopingAmbienceDescription.createInstance(&loopingAmbienceInstance) );
// Get the 4 Second Surge event
FMOD::Studio::ID surgeID = {0};
ERRCHECK( FMOD::Studio::parseID("{7daf5044-5399-490f-bea8-fca399fc8068}", &surgeID) );
FMOD::Studio::EventDescription surgeDescription;
ERRCHECK( system.getEvent(&surgeID, FMOD_STUDIO_LOAD_BEGIN_NOW, &surgeDescription) );
FMOD::Studio::EventInstance surgeInstance;
ERRCHECK( surgeDescription.createInstance(&surgeInstance) );
do
Common_Update();
if (Common_BtnPress(BTN_ACTION1))
// One-shot event
FMOD::Studio::ID pulseID = {0};
#if 1 // look up by path (requires Master Bank.bank.strings to be loaded)
ERRCHECK( system.lookupEventID("/Simple Events/ball impact", &pulseID) );
#else // look up by GUID
ERRCHECK( FMOD::Studio::parseID("{601294bb-ad41-4517-a169-2af4aabe340f}", &pulseID) );
#endif
FMOD::Studio::EventDescription pulseDescription;
ERRCHECK( system.getEvent(&pulseID, FMOD_STUDIO_LOAD_BEGIN_NOW, &pulseDescription) );
FMOD::Studio::EventInstance eventInstance;
ERRCHECK( pulseDescription.createInstance(&eventInstance) );
ERRCHECK( eventInstance.start() );
// Release will clean up the instance when it completes
ERRCHECK( eventInstance.release() );
/*if (Common_BtnPress(BTN_ACTION2))
ERRCHECK( loopingAmbienceInstance.start() );
if (Common_BtnPress(BTN_ACTION3))
ERRCHECK( loopingAmbienceInstance.stop(FMOD_STUDIO_STOP_IMMEDIATE) );
if (Common_BtnPress(BTN_ACTION4))
// Calling start on an instance will cause it to restart if it's already playing
ERRCHECK( surgeInstance.start() );
ERRCHECK( system.update() );
Common_Draw("==================================================");
Common_Draw("Simple Event Example.");
Common_Draw("Copyright (c) Firelight Technologies 2012-2013.");
Common_Draw("");
Common_Draw("Press %s to fire and forget Oneshot Pulse", Common_BtnStr(BTN_ACTION1));
//Common_Draw("Press %s to start Looping Ambience", Common_BtnStr(BTN_ACTION2));
//Common_Draw("Press %s to stop Looping Ambience", Common_BtnStr(BTN_ACTION3));
//Common_Draw("Press %s to start/restart 4 Second Surge", Common_BtnStr(BTN_ACTION4));
//Common_Draw("Press %s to quit", Common_BtnStr(BTN_QUIT));
Common_Sleep(50);
} while (!Common_BtnPress(BTN_QUIT));
ERRCHECK( stringsBank.unload() );
ERRCHECK( masterBank.unload() );
ERRCHECK( system.release() );
Common_Close();
return 0;
