Hi!
I’m very new to FMOD, but am both a musician and a programmer so I’m understanding some of the concepts behind it pretty quickly, since it’s basically an intersection between a DAW and programming logic.
For our next game, I’m trying to do something new with adaptive music, and am trying to figure out if FMOD is the proper tool for the job.
Here is the setup:
- The FMOD project will be integrated with a Unity project.
- We’re making a board game. Between 1 and 4 players can play the game, since it is cooperative.
- At the start of each new game, each player selects 1 of the 8 available characters. That means that each game session will only have 1-4 of the 8 available characters.
- The music has a bed track, which always plays.
- On top of that, there are 1-4 harmony tracks playing. The harmony tracks that are used are based on the characters in the game. For example, if Adam and Bob are in the game, it will play Adam Harmony AND Bob Harmony at the same time. It will NEVER play Charlie Harmony or Daniel Harmony within the whole game, since those characters are not in the game.
- On top of that, there is a single melody track playing at any one time, and this too is based on the characters in the game. For example, if Adam and Bob are in the game, it will play EITHER Adam Melody OR Bob Melody, but not both at the same time. At certain intervals (example every 8 bars), it can either continue playing Adam Melody OR it could switch to Bob Melody (based on some parameters). It will NEVER play Charlie Melody or Daniel Melody, since those characters are not in the game.
- Additionally, the melody that is playing dictations which section the music will transition to next. For example, if Adam Melody is playing in Section 1, it will transition from Section 1 to Section 2. If Bob Melody is playing in Section 1, it will transition from Section 1 to Section 3.
My questions are:
A) Is the above POSSIBLE with FMOD?
B) If so, is it simple enough to do with built-in FMOD features, or would it require a lot of work-arounds and convoluted hacks?
C) How much can be done in FMOD itself, versus having Unity taking some of the logical load?
D) How would you suggest I go about this project?
I have made my own attempt at the above as an example. I had no problem with the bed track and the harmony layers being based on who is in the game. I have a single parameter for each character, which is a Labeled Parameter with 2 values: False and True. If False, they are not in the game, and the harmony layer has no volume. If True, they are in the game, and the harmony layer has full volume.
However, I get stuck when it comes to playing either Adam Melody OR Bob Melody BUT NOT Charlie Melody or Daniel Melody. It seems to me that a multisound is the preferred way of choosing between a set of sounds, but I want it so that only a subset of those multisounds can be chosen based on which characters are in the game, and I don’t know how to do that.
Thank you very much!!
