Hi there,
I have an Issue with FMOD Edit where some of my events just stop making any sounds
Version of FMOD Editor : 2.02.25
What is happening :
I have Event Actions and Event Timelines in my project and I can’t hear some of them. The only thing all of these events have in common, is that they all are in the same Bank. but some of the events of that banks still works.
When did it happened : I’m not exactly sure about that, but It seems that It happened after I added some Parameters to an event with 2 tracks. But as said before, the issue is replicated on other events that are not impacted by these parameters.
What Did i tried :
• Re-install FMOD Editor → Nothing changed
• Check that sound of assets aren’t corrupted → They look fine and I was able to recreate the event with assets used in corrupted events. But after some times the newly created event didn’t work (don’t know if it was after build or redoing)
• Removing Parameters on the Event → Didn’t fixed the issue, other sound without parameters are affected.
• Checking if an effect on the output Bus is blocking the sound to play → Looks good to me, and as said before, some of the sounds that have their output on that bus works
• Removing Effets on MasterTrack → Didn’t change anything
• Checked Device Output → Okay to me, as some of the events works
Other Information :
If I click on Single Instrument Grey Window for the Audio track on broken Event, I can hear the sound
Here’s a screenshoot of the event tracks that I am trying to make works (if anybody can see an issue on that)
Hope my english and explanations are understandable, feel free to ask me any information needed.
Have a nice day ![]()
