Hello.
VCA is added to the project and is checked in GUIDs.txt. However, when I run getVCA(), it says it can’t be found.
Bank loading option is not streaming. Are there any other configuration options?
Bank loading is working fine.
It seems like the bank file was not up to date. If you use getVCA with the above settings, it will be obtained properly.
I’m glad to hear that you managed to resolve the issue!
For posterity, another common cause of this is the strings bank not being loaded. The Studio API uses the strings bank to resolve GUIDs from paths - as a result, the strings bank is required to be loaded if you wish to use any functions that get/set things by path or name.
