Parameter return to 0 after play
I change Parameter
hero.EventInstance.setParameterByName (“Surfaces”, 1);
But after one Play parameter return to 0 again.
How keep this value?
event instances should keep parameter values, unless they stop. You can prevent an event from stopping automatically by setting “Persistant” to ON in FMOD Studio. It’s a setting on the master track of the event.
Other ways to solve this:
if you want 1 to be default, change it to 1 in FMOD Studio, right click and select “Set As Initial Value”
if you want to remember the last value used, you could store it as a variable in unity.
float surfacesValue = 1f;
hero.EventInstance.setParameterByName(“Surfaces”, surfacesValue);
Thanks a lot!
