PlayOneShot not routing through group bus
Hello. I want to use a bus to conveniently change the volume of all sounds belonging to this bus at the same time. But for some reason, when calling the PlayOneShot method, the sound volume does not change, but always remains equal to one. In the FMOD Studio i created event with action sheet and assigned him to UI bank. Bus path in that i changing volume - “bus:/UI”
Have you routed the event to the desired bus in the mixer window?
thanks, it works! ypa
