I don’t understand the probability percentage. If I have 3 transition destinations at the same point in timeline and I want to randomly select any of them, weighted equally, how can I do that?
If I set them to 33.3% and I press play, sometimes the playback head goes past all 3 and non is selected?
Thanks
A solution may be setting the first transition posibility to 33%
The second to
50%
And not applying any probability to the last so that it always traisitions to at least on marker
Ok thanks.
So the general rule of thumb seems to be:
Lets say you have 6 different markers and you want to randomize equally between them.
First marker 100/6=16.6
Second marker 100/5=20
Third marker 100/4=25
Etc
