Profiler Shows no Parameters
I’m trying to troubleshoot a parameter event that’s not responding but my Profiler doesn’t seem to want to show me that there are any parameters on any of my events. Is this normal?
I’m using the GVR plugin set in my project, which explains why I don’t get any volume information from individual events in the profiler, but is parameter info sent through GVR as well?. Here is a screenshot of the profiler:
Hi Benjamin,
You should be able to see the parameters of an event by clicking on it in the 3D Preview on the right hand side (the white dots are event instances). You will see the parameters in the deck after that.
Right click on each parameter and show “Show Graph” to see the changes over time.
Thanks,
Richard
