Request: Features for Embedded Metadata & Markers / Cues
To improve workflow efficiency within FMOD Studio, it would be beneficial to have the below features…
Embedded Audio Metadata
  1. Collapsible metadata viewer in the Asset Browser that lists all the embedded metadata for that audio file
    This would be positioned in the UI near the “Notes” section.
  2. In the metadata viewer, if the user clicks a metadata entry its data gets copied to the clipboard
    Have each entry outlined in a box which changes contrast when hovered over to convey to the user that it can be clicked.
  3. Search-bar filter for metadata in the Asset Browser
    This should also be added as a right-click feature for each metadata entry (for example, you could filter all files that share the same “Actor” name in their metadata).
Embedded Audio Markers / Cues
NOTE: For shorthand sake, I’ll refer to embedded audio markers as “cues”.
  1. Option in “View” menu to toggle visibility in FMOD instruments for cues
    I suggest having the markers be delineated lines within the instrument and position their text (if any) either at the top or bottom so that it doesn’t obscure the waveform.
  2. Feature to convert cues into FMOD logic markers
    This feature would probably merit its own UI interface so the user can specify how the conversion will occur (e.g. Which cues to convert ; The type of logic marker ; Between which two cues will be a region ; Option to rename the logic marker to something other the cue’s name ; etc…)
  3. Callbacks for cues
    This approach is more efficient than having to explicitly create logic markers at the cue points, because if the timing/name of the cues changes then the designer doesn’t have to reposition/rename the logic markers.
    For example, say you have a very long dialogue audio file, cue callbacks can be used to trigger the next subtitle to display.
    Another example (that could not be quickly done with FMOD logic markers), say you have a multi-instrument with audio files of varying durations and they need to have a callback that occurs when their audio reaches a certain point within themselves.
    My team uses Unreal Engine, so I also request that this feature be made into a blueprint node.
As an example for how these features would be useful, in my case…
  • My team uses ASWG metadata on all WAV files to categorize our audio assets, so the ability for our FMOD team to inspect metadata, and to be able to filter files of a certain category would be handy.
  • BWF metadata stores the name of the DAW project that the file was created from, so if there’s an issue with a file then our FMOD team could communicate to the sound designer where the file originated from.
  • Marker / Cue support would be useful to quickly set up, or get callbacks for dialogue subtitles, adaptive music, audiovisual syncs.
Those are all my thoughts. Thank you for reading my post.
Thank you for the feedback! I’ll add your suggestions to our feature and improvement tracker, along with your descriptions of how these features would assist your workflow.
Agreed! Using cues in wave-files can be used for so many useful things, like denoting sections in a music track. Great feature request.
I’ll add you to the list of people interested in this feature. Thanks for the feedback!
This would be of assistance to us at Rainbow Studios as well for engine audio implementations (our prior in-house tech used these cue points heavily)
Lenore
Thanks for the feedback. I’ll add you to the list of people interested in this feature.
Yep, it would be very handy to add markers to .wavs/audio files in external editors and have FMOD recognise them and snap markers/loops/regions to them in the interface etc. At the moment we mark them in wavs externally, inspect the time positions of the markers, and then manually edit the FMOD markers/loop positions to match.
Thanks for the feedback! I’ll add you to the list of people who’ve requested this feature.
Would also really love FMOD to read markers embedded in files!
Understood! I’ll add you to the list of people who’ve requested this feature.
