Hello! I’m trying to use the Resonance Audio plugin, but for some reason it’s cutting fiercely some high frequencies from the moment I activate it and I’m not sure if this is intended or a bug. This problem is consistent with all the sound effects I’ve tried it.
This thread has some further discussion of resonance sounding muffled. I’ve linked the response that sounds like what might be happening in your case - moving the object in the 3D preview window so it is not inside the listener.
