Is there a way to retrieve either event structure or event name from a given event instance using blueprints?
The idea is very simple: I’d like to check if the music actually playing is an instance of a specific event.
Currently the necessary calls to grab the event’s path (eventDescription::getPath()) is currently not available for blueprints. If you need this you will need to use C++ scripting.
