Size of Resonance Audio lib after update fmod to 2.02.04
Hello.
I update fmod plugin to version 2.02.04 and noticed a strong increase in the size of the library "libresonanceaudio.so " for “armeabi-v7a” (650KB → 25MB). At the same time, there were no changes in the file size for other platforms.
This is relevant for both Unity and Unreal.
Resonance audio plugin on github GitHub - resonance-audio/resonance-audio: Resonance Audio Source Code, has a small size for this platform (~450 KB)
I’m not sure but it looks like a bug. If this is not the case, what is the reason for such a change in size?
Debug info was accidentally included in that .so. Our next release will have that debug info removed. For now, you can just strip the debug info from the .so that you have.
