we are trying to integrate a Text-To-Speech feature in our Application. For this, one of the third party plugins is from Oculus using Wit the ‘Understanding Viewer’.
However, they use the Unity AudioSources in a script and I have no idea how to exchange this with FMOD. A simple Event Reference won’t probably not work?
How can I trigger audio from a third party plugin?
I am unfamiliar with Wit or the Understanding Viewer, but the lowest common denominator for an audio application is PCM audio data, and if two audio applications give you access to PCM audio data then you are able to share audio data between those applications.
FMOD allows you to read sound data using Sound::readData, and allows you to write sound data using Sound::lock/ Sound::unlock or a FMOD_SOUND_PCMREAD_CALLBACK.
You mention Wit utilizing Unity Audio Sources; you can hook into the PCM audio data of Unity Audio Sources by implementing OnAudioFilterRead on a monobehaviour, and passing the float[] data into an FMOD Sound. I recommend checking out this thread: Using FMOD with voice chat utilizing OnAudioFilterRead() for a discussion on how to implement OnAudioFilterRead, and using that to pass audio to FMOD.
