Hi:
Since I imported the fmod libary in my android project, I found my app output many logs as follow:
05-28 15:36:55.846: D/AudioTrack(24851): write: 0x7f5a03b080, frames = 512, written = 2048
05-28 15:36:55.846: D/AudioTrack(24851): write: 0x7f5a03b080, userSize = 2048, blocking = 1
05-28 15:36:55.915: D/AudioTrack(24851): write: 0x7f5a03b080, frames = 512, written = 2048
05-28 15:36:55.915: D/AudioTrack(24851): write: 0x7f5a03b080, userSize = 2048, blocking = 1
05-28 15:36:55.916: D/AudioTrack(24851): write: 0x7f5a03b080, frames = 512, written = 2048
05-28 15:36:55.916: D/AudioTrack(24851): write: 0x7f5a03b080, userSize = 2048, blocking = 1
05-28 15:36:55.985: D/AudioTrack(24851): write: 0x7f5a03b080, frames = 512, written = 2048
05-28 15:36:55.985: D/AudioTrack(24851): write: 0x7f5a03b080, userSize = 2048, blocking = 1
ps: I use the non-log version library in my project.
I check the android source code and I don’t find log pattern like that. Does it output by fmod? Anyone who can tell me how it happens? Thanks!
Android
log
It looks like this logging is coming directly from the OS, we will have a ‘fmod’ prefix on our logs.
You could try with our logging libs to see if that may expose some more information.
