FMOD stopped working since updating to Unity 2021.3.22f1 (LTS).
The build works locally from the same commit, and version of everything (even when I delete streamingassets beforehand) , but does not work on our build machine.
- I’ve tried updating Fmod to 2.02.11 and 2.02.13 Unity plugin (and rebuilding banks with studio), neither fixed the issue.
- I’ve tried using FMOD Settings > Bank Import > Source Type > Fmod studio project as well as multi-platform build, neither fixed the issue.
In my batch build script, I do the following.
This worked before upgrading Unity.
FMODUnity.EventManager.RefreshBanks();
FMODUnity.EventManager.CopyToStreamingAssets(options.target);
before building.
These commands seem to error, and the result is that no files are copied into the streamingassets folder.
ALSA lib confmisc.c:165:(snd_config_get_card) Cannot get card index for 0
08:58:43 ALSA lib confmisc.c:165:(snd_config_get_card) Cannot get card index for 0
08:58:43 FMOD Studio: Encountered Error: ERR_OUTPUT_INIT Error initializing output device.
08:58:43 UnityEngine.StackTraceUtility:ExtractStackTrace () (at /home/bokken/build/output/unity/unity/Runtime/Export/Scripting/StackTrace.cs:37)
08:58:43 UnityEngine.DebugLogHandler:LogFormat (UnityEngine.LogType,UnityEngine.Object,string,object[])
08:58:43 UnityEngine.Logger:Log (UnityEngine.LogType,object)
08:58:43 UnityEngine.Debug:LogError (object)
08:58:43 FMODUnity.RuntimeUtils:DebugLogError (string) (at Assets/Plugins/FMOD/src/RuntimeUtils.cs:585)
08:58:43 FMODUnity.EditorUtils:CheckResult (FMOD.RESULT) (at Assets/Plugins/FMOD/src/Editor/EditorUtils.cs:44)
08:58:43 FMODUnity.EditorUtils:CreateSystem () (at Assets/Plugins/FMOD/src/Editor/EditorUtils.cs:534)
08:58:43 FMODUnity.EditorUtils:get_System () (at Assets/Plugins/FMOD/src/Editor/EditorUtils.cs:597)
08:58:43 FMODUnity.EventManager:UpdateCache () (at Assets/Plugins/FMOD/src/Editor/EventManager.cs:179)
08:58:43 FMODUnity.EventManager:RefreshBanks () (at Assets/Plugins/FMOD/src/Editor/EventManager.cs:33)
08:58:43 BuildScripts:Build (UnityEditor.BuildTarget,UnityEditor.BuildTargetGroup,string,UnityEditor.BuildPlayerOptions,bool) (at Assets/_Project/Scripts/Utils/Editor/BuildScripts.cs:75)
08:58:43 BuildScripts:BuildMacos () (at Assets/_Project/Scripts/Utils/Editor/BuildScripts.cs:47)
08:58:43
08:58:43 (Filename: Assets/Plugins/FMOD/src/RuntimeUtils.cs Line: 585)
08:58:43
08:58:43 FMOD Studio: Encountered Error: ERR_INVALID_HANDLE An invalid object handle was used.
08:58:43 FMODUnity.EditorUtils:CreateSystem () (at Assets/Plugins/FMOD/src/Editor/EditorUtils.cs:537)
08:58:43
08:58:43
08:58:43 FMOD Studio: Encountered Error: ERR_INVALID_PARAM An invalid parameter was passed to this function.
08:58:43 FMODUnity.EditorUtils:CreateSystem () (at Assets/Plugins/FMOD/src/Editor/EditorUtils.cs:539)
08:58:43
08:58:43
08:58:43 FMODUnity.EditorUtils:CreateSystem () (at Assets/Plugins/FMOD/src/Editor/EditorUtils.cs:540)
08:58:43
08:58:43
08:58:43
08:58:43
08:58:43 FMOD: Bank refresh failed: WorkFiles/Audio/FMOD/TurboWing/Build/Desktop/Master.strings.bank is not a valid bank.
08:58:43 UnityEngine.Logger:LogFormat (UnityEngine.LogType,string,object[])
08:58:43 UnityEngine.Debug:LogErrorFormat (string,object[])
08:58:43 FMODUnity.RuntimeUtils:DebugLogErrorFormat (string,object[]) (at Assets/Plugins/FMOD/src/RuntimeUtils.cs:593)
08:58:43 FMODUnity.BankRefreshWindow:HandleBankRefresh (string) (at Assets/Plugins/FMOD/src/Editor/BankRefreshWindow.cs:81)
08:58:43 FMODUnity.BankRefresher:HandleBankRefresh (string) (at Assets/Plugins/FMOD/src/Editor/BankRefresher.cs:129)
08:58:43 FMODUnity.EventManager:RefreshBanks () (at Assets/Plugins/FMOD/src/Editor/EventManager.cs:44)
08:58:43
08:58:43 (Filename: Assets/Plugins/FMOD/src/RuntimeUtils.cs Line: 593)
