To start with it might be worth checking that nothing else is sitting on port 9264.
Can you please try the following:
- Close Unity and FMOD Studio
- Open a windows command propmt
- Run the following command to enumerate processes listening on port 9264
netstat -a -n -o | find "9264" - If that yields any results, for example:
then kill those processes:C:\Users\User>netstat -a -n -o | find "9264" TCP 0.0.0.0:9264 0.0.0.0:0 LISTENING 7688 TCP 127.0.0.1:9264 127.0.0.1:64289 ESTABLISHED 7688 TCP 127.0.0.1:64289 127.0.0.1:9264 ESTABLISHED 13804taskkill /pid 7688 /f taskkill /pid 13804 /f
After that, reopen Unity and FMOD Studio and see if you can connect to Live Update.
Please also rollback any changes you have made to the FMOD Unity integration, just to eliminate the possibility of any manual changes causing issues.
