I got this error when I deployed the project to run…
Error: LogPluginManager: Error: Unable to load plugin ‘FMODStudio’. Aborting.
LogPlayLevel: Error: ERROR: Client exited with error code: 1
What versions of FMOD and UE4 are you using?
Are there any other errors or warnings in the console?
I’ve also getting the same error, Using FMOD 2.01.08 and ue4 4.26.1 for oculus build,
Here’s the output
LogPlayLevel: Error: 05-05 12:21:37.150 836 947 D UE4 : LogPluginManager: Error: Unable to load plugin 'FMODStudio'. Aborting.
LogPlayLevel: 05-05 12:21:37.162 836 947 D UE4 : Assertion failed: false [File:E:/CTH_Oculus/Engine/Source/Runtime/Launch/Private/Android/LaunchAndroid.cpp] [Line: 478]
LogPlayLevel: 05-05 12:21:37.162 836 947 D UE4 : Engine Preinit Failed
LogPlayLevel: 05-05 12:21:37.163 836 947 D UE4 : Assertion failed: false [File:E:/CTH_Oculus/Engine/Source/Runtime/Launch/Private/Android/LaunchAndroid.cpp] [Line: 478]
LogPlayLevel: 05-05 12:21:37.163 836 947 D UE4 : Engine Preinit Failed
LogPlayLevel: Error: 05-05 12:21:37.163 836 947 D UE4 : LogAndroid: Error: === Critical error: ===
LogPlayLevel: Error: 05-05 12:21:37.163 836 947 D UE4 : LogAndroid: Error: Assertion failed: false [File:E:/CTH_Oculus/Engine/Source/Runtime/Launch/Private/Android/LaunchAndroid.cpp] [Line: 478]
LogPlayLevel: Error: 05-05 12:21:37.163 836 947 D UE4 : LogAndroid: Error: Engine Preinit Failed
LogPlayLevel: Error: 05-05 12:21:37.163 836 947 D UE4 : LogAndroid: Error: [Callstack] 0x00000000C082F6E0 libUE4.so(0x0000000005C6A6E0)!AndroidMain(android_app*) []
LogPlayLevel: Error: 05-05 12:21:37.163 836 947 D UE4 : LogAndroid: Error: [Callstack] 0x00000000C0845360 libUE4.so(0x0000000005C80360)!android_main() []
LogPlayLevel: Error: 05-05 12:21:37.163 836 947 D UE4 : LogAndroid: Error: [Callstack] 0x00000000C08789C0 libUE4.so(0x0000000005CB39C0)![Unknown]() []
LogPlayLevel: Error: 05-05 12:21:37.163 836 947 D UE4 : LogAndroid: Error: [Callstack] 0x00000000F2830540 libc.so(0x00000000000A5540)![Unknown]() []
LogPlayLevel: Error: 05-05 12:21:37.163 836 947 D UE4 : LogAndroid: Error: [Callstack] 0x00000000F27EA674 libc.so(0x000000000005F674)![Unknown]() []
LogPlayLevel: 05-05 12:21:37.176 836 947 D UE4 : LogAndroid: FAndroidMisc::RequestExit(1)
LogPlayLevel: Took 0.5145064s to run adb.exe, ExitCode=0
LogPlayLevel: Running: C:\Users\CF-7655\AppData\Local\Android\Sdk\platform-tools\adb.exe -s 1WMHH816V80414 logcat -d
Any suggest?
Are you currently using a blueprint-only project?
Hi @cameron-fmod its a c++ project
Previously we have onlky seen this in ‘Blueprint only’ projects, and adding a c++ class to the project would then fix it, are you able to share a project that reproduces the issue? You can upload files to your FMOD Profile.
