Unity: FMOD Reference Updater takes 15minutes to scan
Hi all!
I have a question regarding the speed of FMOD Reference Updater. In our Unity editor, it’s taking incredibly long to scan - 15min in average. Is there a way to speed this up?
I would like to give you more info, but apart from unity scanning every single prefab, item, down to the last corner of the project, I don’t know what else to share with you. Does anyone have any experience with this?
Thank you. :slight_smile:
15 minutes? That sounds wild. I don’t have much experience, but:
Having the project on an SSD or removing unused scenes from your Unity project’s Assets folder should improve scan times.
As a reference for quick it can take, it takes around 40 seconds to scan 64 scenes in my Unity 2D project on my SSD, and 5 seconds to scan the rest (including 313 prefabs). I have a reasonably new gaming laptop.
Thanks for reporting the issue - 15 minutes definitely seems out of the ordinary unless your project is absolutely massive. I’ll do some testing on my end and see whether there’s anything that can be improved, but for reference, can I get you to run the following lines of code to count the assets that the EventReferenceUpdater scans, and provide me with the results?
string[] searchFolders = { "Assets" };
int totalPrefabs = AssetDatabase.FindAssets("t:GameObject", searchFolders).Length;
int totalScenes = AssetDatabase.FindAssets("t:Scene", searchFolders).Length;
int totalScriptableObjects =
    AssetDatabase.FindAssets("t:ScriptableObject", searchFolders).Distinct().ToArray().Length;
Debug.Log("Scanned asset counts:" +
    "\nPrefab count = " + totalPrefabs +
    "\nScene count = " + totalScenes +
    "\nScriptable Object count = " + totalScriptableObjects
Just following up on this; were you able to get around to running the code snippet I posted previously? If not, please give that a shot see what kind of numbers it comes up with for your project.
For now though, I’ve flagged some improvements internally around allowing the scope and specificity of the reference updater’s scan to be changed - for example, toggling whether specific asset types are to be scanned for (GameObject/Scene/ScriptableObjects), and specifying the directories in the asset structure to be scanned instead of scanning the entirety of the Assets folder.
Sorry, Leah, I just now noticed your replies. I will forward this to my team and get back to you.
No problem, please get back to me when you’re able to!
Hi Leah, I finally found time to get back to you. :expressionless:
So, our developer ran your test, and we got this:
Prefab count = 1661
Scene count = 7
Scriptable Object count = 2656
Our developer’s guess on this is that the problem probably doesn’t lie in the number of assets, just the “method” is slow. To him, it looks like it’s threaded but not exactly optimal. This section (posted below) seems to be the bottleneck.
return SearchPrefabs(prefabGuids)
                .Concat(SearchScriptableObjects(scriptableObjectGuids))
                .Concat(SearchScenes(sceneGuids))
                .GetEnumerator();
In his words: “It seems to be building up the structure as it goes, but it would be better to come up with a “smarter” way of “find and replace.” Is this process even multithreaded?” (Of course, you can also talk to our developer, he would be happy to chat with you.)
If you need any additional info from us, let me know. Anything to help us reduce the lengthy scans. :slight_smile:
Best regards!
Thanks for the numbers, Jaka - I’ll do some testing on my end, talk with the development team about this, and get back to you.
Thank you so much, looking forward to hearing from you!
After talking with the development team, given the fact that the 15 minute scan you’re observing is such an outlier to the experience reported by other users, we’d like to do some testing specifically with your project to take a closer look into what exactly is going on.
If possible, could I get you to privately share the Unity project, or a stripped down version where you can still reproduce the extremely long scan, with me? You can do so via your FMOD User Profile.
Just following up on this again - I responded to your DM, but I’m not sure whether you’ve seen my response. Please feel free to send an email to support@fmod.com and link this thread, and we can go from there.
Just bumping on this–My project has been taking over an hour in the FMOD Event Reference Updater to scan after updating from FMOD 2.00 to 2.03 (haven’t worked on the project in a couple years). It seems to be moving, but taking a REALLY long time to get through the scriptableObjects.
e: It finished after around an hour an a half–it got stuck on some large scriptable objects, and then again on a scene that included those large scriptableObjects.
Could I get you to run the code posted earlier in this thread to get a rough count of the scanned objects in your project? Unity: FMOD Reference Updater takes 15minutes to scan - #3 by Leah_FMOD
Also, what version of Unity are you using?
I am having the same issue, takes a long time to scan… Sometimes even freezes. Specifically seems to chug really slowly on prefabs, can’t figure out why. Using an SSD, (MacbookPro M1 Max). Some prefabs take more than 10 minutes just to scan… (or freezes entirely). 2D project.
Edit: I added some quick code to only scan Assets/Prefabs, Assets/Scenes, and Assets/ScriptableObjects. That seems to help, but it still hangs on very large scenes. Could we get some built-in filters in a future update? Scanning the entire Plugins folder and unrelated assets doesn’t seem necessary.
Edit 2 (workaround): The scan speed seems to depend on the scene Unity is in when starting. If I’m in a large/problematic scene, scans take forever, even if that scene itself runs fine. It also matters what scene Unity launched with: if it starts in a heavy scene, switching later doesn’t fix the slow scans. But if I launch Unity with an empty scene, scans run normally. Might be a Unity/Mac issue.
What versions of Unity and FMOD are you using? Also, could I get you to run the code posted earlier in this thread to get a rough count of the scanned objects in your project? Unity: FMOD Reference Updater takes 15minutes to scan - #3 by Leah_FMOD
I’ve noted your interest in this on our internal improvement tracker.
I am using FMOD 2.02.29 (tried 2.03 but it performs the same)
Prefab count = 616
Scene count = 154 (high scene count is from some plugins that have 50+ example scenes)
Scriptable Object count = 725
Could we please get filters? To filter out problematic assets, scenes, plugins folders etc. I’ve implemented some of this myself, but would be nice built in.
Its still having hick-ups though on prefabs for no reasons, scanning a single prefab for 10-15 minutes, or sometimes forever. As I said, it depends on if Unity was opened with an empty scene, or with a large scene (many prefabs etc). Please forward that clue too
Apologies for the delayed response.
Thanks for getting those numbers for me!
Thanks, I have passed this and the edits to your previous post to the development team.
If possible, could I get you to upload your Unity project to your FMOD user profile for me to take a closer look at? Having a solid repro case would definitely help us in identifying exactly what the issue is.
Hey @Bacall, just to follow up on this - is it possible that you can share your project with us? If not,
Could I get you to share what these plugins are so we can test with them specifically?
I can’t share the project, it’s very large, but I will try to recreate the issue in a new project. Let me get back to you on that one.
I am often using these Assets/plugins (most suspicious):
  • Odin Inspector and Serializer
  • Odin Validator
  • Hot Reload
  • All Kubacho Labs tools (vFolders 2, vInspector 2, vHierarchy 2, vInspector 2, vTabs 2 etc)
Other assets/plugins, probably don’t mess with stuff as much: Game 2D Water Kit, Input Icons for Input System, Pro camera 2D, Text Animator for Unity, Transform Tools, MK Glow, Translucent Image, Easy Save (ES3), Dialogue System.
Thanks for the plugin list - I’ve passed it along to the development team to look at how they interact with the event reference updater. If you’re able to exactly recreate the issue, or turn up any more info, please feel free to let me know.
