I am havign a strange issue that is affecting my team and a large project we are part of.
We have “FMOD 2.02.15, 64bit, built #134211” set up and have been using it for several months with varying degrees of success with “Unreal 4.27.2”. We went the route of versioning our .bank files through perforce, which are stored in FMOD/Main/ in the project, and then allowing Unreal to generate all other project files locally on everyone’s machines in the FMOD folder as per the FMOD documentation.
This worked well for us initially but we are now running into a strange issue. The easiest way to illustrate the problem is when a team member syncs the unreal project at the latest revision and loads up the editor. It generates project files from the .bank files as expected, but once complete, Unreal has seemingly lost ALL FMOD event/bank etc. references in all blueprints. Reloading banks doesn’t help. We get an initial error message… unable to load asset lookup, unable to load bank lookup. The only fix is to close the editor, and reopen it, at which point all the references are perfectly fine, and the errors don’t reappear.
After some testing it appears that the problem stems from the bank.uasset files being regenerated. deleting just the events folder, or buses, private integration data, etc all seem to regenerate fine. Deleting the banks folder where the bank.uasset files are stored results in lost references unless the project is closed and reopened a second time. Deleting the events folder AND the banks folder results in even more references being lost. Luckily it seems to be temporary unless someone specifically goes into the blueprints and saves them with the missing refs, which then saves them in that state.
The team on this game is very large and the same issue affects everyone. While it is possible to get around, it has caused us quite a few misunderstandings and confusion among the dev team and us on the audio team as well. Any help would be greatly appreciated, I can provide some error screenshots with blurred-out paths and game names if necessary.
I have not been able to reproduce this issue with your versions. Are you using a launcher build or source build of UE4.27?
Just as a test (not suggesting this as a workaround), if you delete the generated Banks directory and rebuild generated assets through the commandlet before opening the editor, does that allow it to open with unbroken links?
If you could please upload your editor log to your FMOD Profile that would also help with my investigation.
We have a very similar issue on UE 5.3.
From what I can tell it is related to load/execution order.
For example our character (which references some FMOD events), is reference by the GameMode in Unreal. This is loaded very early on when booting the editor (loaded with the level)
I think what happens is that the character is loaded before the new FMOD events have been generated, and therefore cannot be referenced and get nulled out. This would also explain why it works the second time, because the FMOD assets are now created before loading the blueprint.
Running the generate command before opening the editor also works, but is not a good solution for us, as people will forget and cause lost references to be checked back in.
Looking at the FMOD Plugin code, the FMOD assets are not generated until all the “other assets” are loaded, which is too late.
We made a modification which has not seemed to have any adverse effects yet, (but are keeping an eye on it) to generate the assets immediately in FFMODStudioEditorModule::OnPostEngineInit instead of waiting for all other assets to be loaded.
Does that seem like a reasonable solution?
Unfortunately, we haven’t made any progress on the issue.
Could you please let me know what version of the FMOD integration you are using?
Are you working with a large team using source control, similar to the OP?
Additionally, could you provide the reproduction steps when encountering the issue? For example, does it happen after pulling changes and launching UE for the first time?
In Windows File Explorer, navigate to Content/Fmod/Desktop
Delete old bank files
Replace with updated bank files
Open Unreal, sounds are broken even though the events are okay.
Close and reopen Unreal, everything is fine.
I then push the updated banks and have had some issues with automated builds using Jenkins. Adding the commandlet there as a step before building seems to have helped.
I’ll do some testing to pull down on another machine to see what happens in Unreal specifically for other team mates. No one had mentioned anything but they arent audio people and since its working in builds they may not have noticed/cared.
Unfortunately, I am still unable to reproduce the issue.
Would it be possible to get a stripped-out copy of the project uploaded to your project uploaded to profile? Please note you must register a project with us before uploading files.
We’re having the same issues on 5.7. The FMOD Uassets are not committed in our GIT-repo. If we remove the generated files from disk and restart Unreal the references to the newly generated files are gone. We tried to generate them earlier in Editor startup, but same issue occurs. Any updates on this?
Do you have consistent reproduction steps for the issue? Is this happening on the same PC of when pulling from source control? Any info would be great, thank you
This happens when we start from a clean Content/FM0D-generated state.
For example, if a new team member syncs the project from Git, or if we clear the generated FMOD content locally to match what is actually versioned in our Git repo, then start the Unreal Editor.
In that first editor launch, FMOD regenerates the missing generated assets from the banks, but some Blueprint references appear to be loaded before those FMOD assets exist, so the references show up as missing/null. If we then close and reopen the editor, everything resolves correctly.
So the issue is mainly when the generated FMOD content is absent at editor startup, like for a fresh checkout, a clean workspace, or a clean build machine. It is especially risky because if someone opens a Blueprint during that first broken session and saves it, the missing references can become permanently saved.
