BankLoadException ERR_MEMORY WebGL build in Oculus Quest browser
I have this memory error when loading the only bank of the project, which is a 55.6 MB file.
Is it too heavy ?
The error occurs in the Quest browser, but it loads fine in a desktop browser.
Messages from the console:
[FMOD] loadFromWeb. Path = https://myaddress.com:8000/StreamingAssets/FModBanks/Master.bank, result = ERR_MEMORY.
BankLoadException: [FMOD] Could not load bank ‘https://myaddress.com:8000/StreamingAssets/FModBanks/Master.bank’ : ERR_MEMORY : Not enough memory or resources.
at FMODUnity.RuntimeManager.loadedBankRegister (FMODUnity.RuntimeManager+LoadedBank loadedBank, System.String bankPath, System.String bankName, System.Boolean loadSamples, FMOD.RESULT loadResult) [0x00000] in <00000000000000000000000000000000>:0
Thank you for your help.
Pierre
Those error messages do usually indicate a shortage of memory.
Does the issue still occur if you try making an extremely small and simple bank, and attempt to load that in the Oculus Quest browser?
