Broken banks reference
Updating my plugin to the latest version (2.02.28) available to Unity Asset Store broke all of my banks reference.
I’m using banks stubs as my input type is set to Asset Bundle.
Any help on how to debug this problem?
Unity 2022.3.53f1
Can I get you to elaborate on what specifically has broken with the references? For example, are your banks not properly processed or unselectable in editor? Do they fail to load at runtime? etc.
Some other questions for you as well:
  • What version of FMOD for Unity were you using prior to updating to 2.02.28?
  • What errors, if any, do you receive in the Unity editor from FMOD when not in play mode?
  • Could I get you to set FMOD’s logging level to “Log”, enable API error logging, and post a log from play mode?
