BUG: Fmod 1.10 and 1.09.10 not building in Unity Android
The following error is generated when I build an Android project with fmod studio. This error is not produced in 1.09.04 so you can use that as an alternative in the meantime.
Assets/Plugins/FMOD/RuntimeManager.cs(576,29): error CS0120: An object reference is required to access non-static member `FMODUnity.RuntimeManager.loadedBankRegister(FMODUnity.RuntimeManager.LoadedBank, string, string, bool, FMOD.RESULT)’
Steps to reproduce:
Download Fmod studio 1.10.XX
Download Fmod Unity 1.10.XX
Open fmod project
Create 3D event, add audio clip with loop region, assign to master bank.
Build for all platforms.
In Unity:
Create new project
Import integration 1.10.XX
Assign fmod project
Create event emitter and assign event
Add studio listener to camera
Switch platform to android
Add scene to build path
Build
Edit: if you comment that line, Unity is building and build is working fine.
Same problem here, Unity2017.3.1f1.
Assets/Plugins/FMOD/RuntimeManager.cs(576,29)…
I can’t 1.09.04 - console is informing me that the code is obsolete, when I change one obsolete line I got 25 next errors.
This issue has been fixed for the next release, the change can be found on our github page:
The function should have been accessed through the ‘Instance’ of the RuntimeManager.
Instance.loadedBankRegister(…
This fix worked for me. Do you have any roadmap/date when this will be availabe in release?
This fix will be in the next release, due at the start of May.
