Can we use fmod with videoplayer
when we use fmod plugin, we disable unity’s internal audio system, so we can not listen the sound in mp4.
can we use fmod to listen the sound from mp4.
the way i knew is extract audio from mp4, but the problem is not sync. so has any other good ways?
The recommended approach is to take the audio from the video and play that manually from FMOD and handle the synchronization yourself. If you are having synchronization issues however then you can try leaving Unity Audio enabled and it shouldn’t cause any major issues- unless you are packaging to Xbox.
I’m am guessing that by “extract audio from mp4”, you mean to load in Unity the audio and the video as two different files, right?
If so, instead of that, you might want to try using the AudioSampleProvider:
Basically, on the VideoPlayer script, you set the “Audio Output Mode” to “API Only”, add a script similar to the example on the link above, and then send the audio samples you’re getting to FMOD.
the audiosampleprovider provides less than adequate results because you get a lot of popping which only can be reduced by increasing the latency
unless I’m doing something wrong
not to mention that it doesn’t work half the time, sometimes even causing Unity to outright crash
Hi, just wanted to share that I also had a lot of problems with the FMOD video playback sample https://www.fmod.com/docs/2.03/unity/examples-video-playback.html, and have attached a rewrite that fixes these issues:
  • Works on macOS (AudioSampleProvider callback doesn’t get called on macOS, presumably a Unity bug, so uses polling in update instead), also tested on Windows.
  • Writes to end of write cursor instead of to last read cursor, fixes stuttering playback
  • Pauses playback until buffer is filled, fixes stuttering playback
  • Buffers through one NativeArray instead of allocating/resizing/copying through multiple C# lists and arrays
  • Removed dynamic resampling based on latency measurement, should not be necessary
using Unity.Collections;
using UnityEditor;
using UnityEngine;
using UnityEngine.Experimental.Audio;
using UnityEngine.Experimental.Video;
using UnityEngine.Video;
using System;
using UnityEngine.UIElements;
using Unity.Collections.LowLevel.Unsafe;
/// <summary>
/// Route video audio through FMOD; based on
/// https://www.fmod.com/docs/2.03/unity/examples-video-playback.html
/// - Poll in Update instead of using SampleFramesAvailable event, as the event is not invoked on macOS
/// - Avoid buffering through C# list, rely on AudioSampleProvider's internal buffer and lock/unlock FMOD sound directly
///   with one intermediate temp NativeArray buffer
/// - Pause channel until buffer is filled
/// - Write samples after write cursor instead of after last frame's read cursor to fix stuttering
/// </summary>
public class VideoPlayerAudioPlayer : MonoBehaviour
    private const int LATENCY_MS = 50;
    private VideoPlayer mVideoPlayer;
    private AudioSampleProvider mProvider;
    private FMOD.CREATESOUNDEXINFO mExinfo;
    private FMOD.Channel mChannel;
    private FMOD.Sound mSound;
    private uint mWriteCursor;
    void Start()
#if UNITY_EDITOR
        EditorApplication.pauseStateChanged += EditorStateChange;
#endif
#if UNITY_EDITOR
    private void EditorStateChange(PauseState state)
        if (mChannel.hasHandle())
            mChannel.setPaused(state == PauseState.Paused);
#endif
    private void OnDestroy()
        mChannel.stop();
        mSound.release();
#if UNITY_EDITOR
        EditorApplication.pauseStateChanged -= EditorStateChange;
#endif
    public void Setup(VideoPlayer videoPlayer)
        this.mVideoPlayer = videoPlayer;
    public void OnLoopPointReached(VideoPlayer vp)
        if (!vp.isLooping)
            mChannel.setPaused(true);
    public void OnPrepared(VideoPlayer vp)
        mProvider = vp.GetAudioSampleProvider(0);
        int sampleRate = (int)(mProvider.sampleRate * mVideoPlayer.playbackSpeed);
        uint targetLatencySamples = (uint)(sampleRate * LATENCY_MS) / 1000;
        mExinfo.cbsize = Marshal.SizeOf(typeof(FMOD.CREATESOUNDEXINFO));
        mExinfo.numchannels = mProvider.channelCount;
        mExinfo.defaultfrequency = sampleRate;
        mExinfo.length = targetLatencySamples * (uint)mExinfo.numchannels * sizeof(float);
        mExinfo.format = FMOD.SOUND_FORMAT.PCMFLOAT;
        FMODUnity.RuntimeManager.CoreSystem.createSound("", FMOD.MODE.LOOP_NORMAL | FMOD.MODE.OPENUSER, ref mExinfo, out mSound);
        FMOD.ChannelGroup channelGroup;
        FMODUnity.RuntimeManager.CoreSystem.getMasterChannelGroup(out channelGroup);
        FMODUnity.RuntimeManager.CoreSystem.playSound(mSound, channelGroup, true, out mChannel);
    private void Update()
        if (!mVideoPlayer || !mVideoPlayer.isPrepared)
            return;
        uint availableSamples = mProvider.availableSampleFrameCount;
        if (availableSamples > 0)
            mChannel.getPosition(out uint readCursorLoop, FMOD.TIMEUNIT.PCMBYTES);
            uint writeCursorLoop = mWriteCursor % mExinfo.length;
            uint maxWriteBytes = readCursorLoop - writeCursorLoop;
            if (readCursorLoop < writeCursorLoop || mWriteCursor == 0)
                maxWriteBytes += mExinfo.length;
            if (maxWriteBytes > 0)
                using (var buffer = new NativeArray<byte>((int)maxWriteBytes, Allocator.Temp))
                    uint samples = mProvider.ConsumeSampleFrames(buffer.Reinterpret<float>(1));
                    uint bytes = samples * (uint)mExinfo.numchannels * sizeof(float);
                    var res = mSound.@lock(writeCursorLoop, bytes, out IntPtr ptr1, out IntPtr ptr2, out uint lenBytes1, out uint lenBytes2);
                    if (res != FMOD.RESULT.OK) Debug.LogError(res);
                    unsafe
                        byte* src = (byte*)buffer.GetUnsafeReadOnlyPtr();
                        UnsafeUtility.MemCpy((byte*)ptr1, src, lenBytes1);
                        UnsafeUtility.MemCpy((byte*)ptr2, src + lenBytes1, lenBytes2);
                    res = mSound.unlock(ptr1, ptr2, lenBytes1, lenBytes2);
                    mWriteCursor += bytes;
        if (mWriteCursor >= mExinfo.length)
            mChannel.setPaused(false);
#if UNITY_EDITOR
        if (mChannel.hasHandle() && mChannel.getChannelGroup(out var channelGroup) == FMOD.RESULT.OK)
            channelGroup.setMute(EditorUtility.audioMasterMute);
#endif
Thanks for sharing your rewrite! This polling approach eliminates a lot of the complexity required to keep FMOD synchronized with the video player. I’ll pass on your improvements to the Dev team to see if we can incorporate them in the video playback example.
Is there someway this could be easily modified to be fed back into FMOD Studio as an Event Reference?
I’m effectively playing videos on Televisions in the world and I need to use the Spatializer plugin. Currently this is my final issue with using your improved code. I’m thinking it might be possible with a Programmer Instrument but I can’t seem to find how that might work from Unity.
