Error CS0839: Argument missing
hello i get this error in line 16 and 22 and what i miss to work the code this it :
using System.Collections;
using UnityEngine;
public class FMODEng : MonoBehaviour
FMOD.Studio.EventInstance CarEngine;
FMOD.Studio.PARAMETER_ID RPM;
FMOD.Studio.PARAMETER_ID AccelInput;
PG.CarController uvc;
void Awake()
	FMOD.Studio.EventDescription RpmEventDescription;
	CarEngine.getDescription(out, RpmEventDescription);
	FMOD.Studio.PARAMETER_DESCRIPTION RpmParameterDescription;
	RpmEventDescription.getParameterDescriptionByName("RPM", out RpmParameterDescription);
	RPM = RpmParameterDescription.id;
	FMOD.Studio.EventDescription AccelInputEventDescription;
	CarEngine.getDescription(out, AccelInputEventDescription);
	AccelInputEventDescription.getParameterDescriptionByName("AccelInput", out AccelInputParameterDescription);
	AccelInput = RpmParameterDescription.id;
	uvc = GetComponent<PG.CarController>();
void Start()
	FMODUnity.RuntimeManager.AttachInstanceToGameObject(CarEngine, GetComponent<Transform>(), GetComponent<RigidBody>());
	CarEngine.start();
void FixedUpdate()
	CarEngine.setParameterByID(RPM, uvc.EngineRPM);
void CheckAccel()
	if(uvc.MinRPM >= uvc.EngineRPM)
		CarEngine.setParameterByID(AccelInput, 0f);
	else if(uvc.MinRPM <= uvc.EngineRPM)
		CarEngine.setParameterByID(AccelInput, 1f);
Hi!
There are commas in the function calls that shouldn’t be there. Removing them should fix the issue.
