Thanks for the quick reply.
Dont know if its important, but its a code project.
I’m not quite sure what you mean by the “default debug filter” in " Other than that, is the Find Event by Name node returning anything at all when you watch the value and run with the default debug filter?" but if the “Play 2D event” with the corresponding Event is not put inside the BP, it returns nothing.
With node: Return value from Event by Name === TheGreatEvent
No node: With node: Return value from Event by Name ===
If you by “Add an Output Log to your Blueprint window” mean just open an output log window this is the output from the editor (working without “play 2D event” node):
LOG from editor:
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi.cpp(3970) - filename = ../../../../../UE_LocalProjects/FMOD_QUEST_TEST/Content/FMOD/Desktop/Master.bank : mode 02010082
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi.cpp(3974) - FMOD_NONBLOCKING specified. Putting into queue to be opened asynchronously!
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_thread.cpp(209) - Init FMOD nonblocking thread (0). Affinity: 0x8000000000000003, Priority: 0xFFFF7FFC, Stack Size: 114688, Semaphore: Yes, Sleep Time: 0, Looping: Yes.
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi.cpp(4111) - setdata soundi = 000002679794FC88 : node = 0000026797953EE0
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi.cpp(4115) - add node to async list : head = 000002678DF479D8. list count = 0
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_async.cpp(191) - Starting Asynchronous operation on sound 000002679794FC88
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(641) - Create name='../../../../../UE_LocalProjects/FMOD_QUEST_TEST/Content/FMOD/Desktop/Master.bank', mode=0x02010082
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(647) - exinfo->cbsize = 224
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(651) - exinfo->length = 284288
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(655) - exinfo->fileoffset = 2304
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(679) - exinfo->numsubsounds = 1
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(683) - exinfo->inclusionlist = 0000026797953FF0
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(687) - exinfo->inclusionlistnum = 1
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(719) - exinfo->suggestedsoundtype = 5
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(763) - exinfo->initialseekpostype = 1
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(1397) - Stream 0/1: name='mainthemes_09_JFL_skyelves_L1', format=5, channels=2, frequency=48000, lengthbytes=284000, lengthpcm=959634, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.717590.
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_thread.cpp(209) - Init FMOD file thread. Affinity: 0x8000000000000003, Priority: 0xFFFF7FFC, Stack Size: 49152, Semaphore: No, Sleep Time: 10, Looping: Yes.
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_async.cpp(336) - Finished Asynchronous operation on sound 000002679794FC88
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_soundi.cpp(436) - mainthemes_09_JFL_skyelves_L1 (000002679794FC88)
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_soundi.cpp(436) - mainthemes_09_JFL_skyelves_L1 (0000026797937C88)
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_soundi.cpp(436) - mainthemes_09_JFL_skyelves_L1 (0000026797937AC8)
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_thread.cpp(165) - FMOD Studio update thread finished.
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_thread.cpp(165) - FMOD Studio bank load thread finished.
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_profile.cpp(138) - Profiler disconnecting all clients
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_thread.cpp(165) - FMOD Studio sample load thread finished.
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\studio_api\src\fmod_liveupdate.cpp(414) -
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\studio_api\src\fmod_liveupdate.cpp(291) - Reset connection (reason Disconnected)
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_thread.cpp(165) - FMOD stream thread finished.
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_thread.cpp(165) - FMOD mixer thread finished.
LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi.cpp(930) - Closed.
Packaged for windows - No node - Log:
[2021.08.10-07.58.25:982][370]LogBlueprintUserMessages: [NewMap_C_1] Trying to find event by name::: ->>>
[2021.08.10-07.58.25:982][370]LogSlate: Took 0.000242 seconds to synchronously load lazily loaded font '../../../Engine/Content/Slate/Fonts/Roboto-Regular.ttf' (155K)
[2021.08.10-07.58.28:422][397]LogBlueprintUserMessages: [NewMap_C_1] QUITING
Packaged for windows - With node - Log:
[2021.08.10-08.00.32:381][343]LogBlueprintUserMessages: [NewMap_C_2] Trying to find event by name::: ->>>
[2021.08.10-08.00.32:381][343]LogStreaming: Display: FlushAsyncLoading: 1 QueuedPackages, 0 AsyncPackages
[2021.08.10-08.00.32:382][343]LogSlate: Took 0.000242 seconds to synchronously load lazily loaded font '../../../Engine/Content/Slate/Fonts/Roboto-Regular.ttf' (155K)
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi.cpp(3970) - filename = ../../../FMOD_QUEST_TEST/Content/FMOD/Desktop/Master.bank : mode 02010082
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi.cpp(3974) - FMOD_NONBLOCKING specified. Putting into queue to be opened asynchronously!
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_thread.cpp(209) - Init FMOD nonblocking thread (0). Affinity: 0x8000000000000003, Priority: 0xFFFF7FFC, Stack Size: 114688, Semaphore: Yes, Sleep Time: 0, Looping: Yes.
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi.cpp(4111) - setdata soundi = 00000280D283C9C8 : node = 00000280B8A903A0
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi.cpp(4115) - add node to async list : head = 00000280B7F4D8D8. list count = 0
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_async.cpp(191) - Starting Asynchronous operation on sound 00000280D283C9C8
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(641) - Create name='../../../FMOD_QUEST_TEST/Content/FMOD/Desktop/Master.bank', mode=0x02010082
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(647) - exinfo->cbsize = 224
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(651) - exinfo->length = 284288
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(655) - exinfo->fileoffset = 2304
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(679) - exinfo->numsubsounds = 1
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(683) - exinfo->inclusionlist = 00000280B8A904B0
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(687) - exinfo->inclusionlistnum = 1
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(719) - exinfo->suggestedsoundtype = 5
[2021.08.10-08.00.32:387][345]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(763) - exinfo->initialseekpostype = 1
[2021.08.10-08.00.32:388][346]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_systemi_sound.cpp(1397) - Stream 0/1: name='mainthemes_09_JFL_skyelves_L1', format=5, channels=2, frequency=48000, lengthbytes=284000, lengthpcm=959634, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.717590.
[2021.08.10-08.00.32:389][346]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_thread.cpp(209) - Init FMOD file thread. Affinity: 0x8000000000000003, Priority: 0xFFFF7FFC, Stack Size: 49152, Semaphore: No, Sleep Time: 10, Looping: Yes.
[2021.08.10-08.00.32:390][347]LogFMOD: c:\jk\workspace\2.1_UE4.26_Win64\core_api\src\fmod_async.cpp(336) - Finished Asynchronous operation on sound 00000280D283C9C8
[2021.08.10-08.00.35:685][729]LogBlueprintUserMessages: [NewMap_C_2] QUITING
