FMOD errors with Unity Multiplayer Play Mode (MPPM)
When starting a new player instance in MPPM I get this error:
[FMOD] FMOD_OS_Net_Listen : Cannot listen for connections, port 9264 is currently in use.
and when trying to play a sound, it works fine in the main window, but in the player2 window I get:
[FMOD] ObjectLookup::get : Lookup failed for EventModel: {someUUID}
[FMOD] Event not found: {someUUID} (event:/someEvent)
there’s a workaround explained in Multiplayer Play Mode FMOD audio - #4 by EdEddnEddy - Unity Engine - Unity Discussions that seems to be working for the second issue, it would be nice to integrate that fix in the unity plugin to make sure MPPM is supported out of the box.
Thank you for bringing this to our attention.
This relates to the FMOD system listening for the Live Update port. Since there are multiple systems running at the same time they are all trying to connect. It can be disabled in the integration settings:
I have made a task to investigate resolving the other issues.
in case this can help find a fix for Unity MPPM, here’s the hackish updates I did to get fmod 2.03.08 working in the virtual player of MPPM:
in Assets/Plugins/FMOD/src/RuntimeUtils.cs, added this method:
        public static string ToVirtualPlayerFriendlyPath(string bankPath)
#if UNITY_EDITOR
            if (IsVirtualPlayer() == false)
                // Editor: regular player, leave the path as is.
                return bankPath;
            return System.IO.Path.Combine("../../../", bankPath);
            // https://discussions.unity.com/t/multiplayer-play-mode-get-player-id/1578742/3
            bool IsVirtualPlayer()
                const string vpIdArg = "-vpId";
                var args = Environment.GetCommandLineArgs();
                foreach (var arg in args)
                    if (arg.StartsWith(vpIdArg))
                        return true;
                return false;
#else
    // Runtime: do not adjust the path in any way.
    return bankPath;
#endif
and I use it in
FMODUnity.PlatformPlayInEditor.GetBankFolder
        //string bankFolder = globalSettings.SourceBankPath;
        string bankFolder = RuntimeUtils.ToVirtualPlayerFriendlyPath(globalSettings.SourceBankPath);
FMODUnity.BankRefresher.UpdateFileWatcherPath
        //string sourceBankPath = Settings.Instance.SourceBankPath;
        string sourceBankPath = RuntimeUtils.ToVirtualPlayerFriendlyPath(Settings.Instance.SourceBankPath);
FMODUnity.EditorUtils.ValidateSource
            // if (!File.Exists(settings.SourceProjectPath))
            if (!File.Exists(RuntimeUtils.ToVirtualPlayerFriendlyPath(settings.SourceProjectPath)))
                // string buildFolder = RuntimeUtils.GetCommonPlatformPath(Path.Combine(projectFolder, BuildFolder));
                string buildFolder = RuntimeUtils.ToVirtualPlayerFriendlyPath(RuntimeUtils.GetCommonPlatformPath(Path.Combine(projectFolder, BuildFolder)));
FMODUnity.EventManager.UpdateCache
            //defaultBankFolder = RuntimeUtils.GetCommonPlatformPath(Path.Combine(settings.SourceBankPath, platform.BuildDirectory));
            defaultBankFolder = RuntimeUtils.ToVirtualPlayerFriendlyPath(RuntimeUtils.GetCommonPlatformPath(Path.Combine(settings.SourceBankPath, platform.BuildDirectory)));
with those changes, sounds work in both main editor and MPPM “virtual players”.
Thank you for sharing your solution. I will add your notes to the task!
Just curious, has this issue been fixed, or is it still being looked at? I can not for the life of me get MPPM to work with FMOD even with all the included changes. At this point I’m just thinking of using ParrelSync since I’ve heard that it actually works.
thank you for checking in!
It’s still on our backlog at the moment.
At this stage, there’s no specific ETA, but we’ll be sure to post here once it moves forward or when there’s any progress to share.
for anyone still wondering about this. 2 bits of good news :
The mute issue seems to be fixed in 6.3 and there is a workaround for the listen for connections. Instead of the ToVirtualPlayerPath in runtime utils having a local method to discover if its a virtual player, use this instead :
 public static bool IsVirtualPlayer()
#if UNITY_EDITOR
                    return true;
            return false;
#else
            return false;
#endif
#if UNITY_EDITOR
            if (!IsVirtualPlayer())
                return bankPath;
#else
            return bankPath;
#endif
This way you can call it from anywhere, then add a check to the RuntimeManager.Initialize like so
if (currentPlatform.IsLiveUpdateEnabled && !RuntimeUtils.IsVirtualPlayer())
That way the listener will still be active (if its active on your platform) for builds and the main unity instance and you can still connect but will be disabled on the virtual player. With all these fixes it feels native now
