Where can I find the current FMOD version in Unity imported plugin?
Unity version is 6000.1.14.
I tried to update to latest version but then it could not find dlls for Steam Audio.
Steam Audio is currently not used, but v4.6.1 is imported in the project, we plan to use it once FMOD works. We cannot update Steam Audio to latest version, because on play it immediately crashes the editor. This version of SA works with the FMOD, but no matter if we enable it or not, the audio output is incorrect.
I will try to create new simple project, reproduce the problem and share it.
I have checked your project and confirmed it uses 2.03.09, which matches the latest FMOD Studio version at the time you mentioned.
Unfortunately, I was not able to reproduce the issue you described. When testing the project in Quest 2 Link mode, everything worked as expected on my end. The sound output came directly from the headset instead of the PC speakers. The sound also follows head rotation and spatialization behaved correctly when moving around the FMOD sound GameObject.
Could you please set the Logging Level to Log and enable API Logging, then share the full log, so I can compare it with my local setup and see if there’s anything different that could explain the behavior?
With Quest link there is sometimes problem, that it steals all the PC audio. So in your case it could possibly send the audio to PC, but quest link forced it to the headset. Please verify if you stop the game, that any sound (e.g. youtube) is going to PC and not the headset.
I tried it on 2 PCs, both have same problem:
Win10 with Reverb G2 and Quest 2
Win11 with Quest 3 and different Quest 2
I’m sending the log, this is from the test project:
Based on my testing, it looks like the audio routing depends entirely on which Windows output device is set as the default before entering Play Mode.
If Windows is set to my PC headset by default, the first launch mirrors audio to both the PC and the Quest headset, and the second launch outputs only to the PC headset.
If Windows is set to “Oculus Virual Audio Device” by default, all FMOD audio outputs correctly to the Quest headset only.
This suggests the issue on your side may be related to Windows automatically switching the default audio device when Quest Link is active.
Could you please check which device is selected as your Windows default output right before you enter Play Mode, and whether it changes automatically when you start the scene?
How the audio switching works correctly for all VR games (including Unity audio):
Default windows audio output is set to speakers
If you launch a VR game, depending on the driver:
WMR - it will switch windows audio output to the headset on driver start and switch it back when you close WMR
Quest - general apps will go to speakers but VR apps will go to the headset, it does not switch default audio output
What happens with FMOD:
Today it handled WMR well, the sound was working correctly in the hadset (but some other days it did not work)
It cannot handle Quest’s behaviour - it still sends audio to the default output
If i manually switch default audio output to Quest, it works - but this is unacceptable for end users
I have question, was there ever a VR game made in Unity using FMOD ? It looks like FMOD does not expect this behaviour and it needs to be implemented on your side and tested on all headsets (Index, Pico, Quests, WMR, HTC, Pimax, …). If not properly tested, FMOD is not production ready for VR.
We do have a scripting example for targeting Oculus audio output, but the version in the documentation was originally written for the Oculus Rift: Scripting Examples | Oculus Setup
I have updated the callback script to work with Quest based devices (Quest 2 / Quest 3 via Link), and after testing on my side it consistently prevents audio from being routed to the wrong Windows output device.
Here is the updated version:
using System;
using UnityEngine;
[CreateAssetMenu(menuName = "Oculus FMOD Callback Handler")]
public class OculusFMODCallbackHandler : FMODUnity.PlatformCallbackHandler
public override void PreInitialize(FMOD.Studio.System studioSystem, Action<FMOD.RESULT, string> reportResult)
FMOD.System coreSystem;
FMOD.RESULT result = studioSystem.getCoreSystem(out coreSystem);
reportResult(result, "studioSystem.getCoreSystem");
int driverCount = 0;
result = coreSystem.getNumDrivers(out driverCount);
reportResult(result, "coreSystem.getNumDrivers");
for (int i = 0; i < driverCount; i++)
int rate;
int channels;
System.Guid guid;
FMOD.SPEAKERMODE mode;
result = coreSystem.getDriverInfo(i, out string name, 256, out guid, out rate, out mode, out channels);
reportResult(result, "coreSystem.getDriverInfo");
if (name.Contains("Oculus Virtual"))
result = coreSystem.setDriver(i);
reportResult(result, "coreSystem.setDriver");
break;
This forces FMOD to select the Oculus Virtual Audio Device during initialization, which keeps audio output on the Quest headset even if Windows changes the default audio endpoint when Link becomes active.
Spatialization also worked as expected during my testing.
Could you please give this a try and let me know if the issue persists?
Thanks for the script, unfortunately this cannot possibly work for these reasons:
It will switch audio also for other headsets (like WMR or SteamVR), so the sound will not work for them
Audio output name is localized, you cannot find it reliably by name
Even if you get the correct output for Oculus, it will not cover future drivers or if some of the existing drivers change their behaviour in the future
In theory you can let the user select the correct output, but:
Major inconvenience for the user, all other VR apps handle this automatically
They will have to set it every time if they switch headset, driver switches behaviour or changed system localization
So it goes to my previous post:
It should be handled in the FMOD internally
It should cover all existing and future headsets
There should be no required additional scripting for developers, if they want Unity’s default behaviour
There should be no required setting for the end user
Please can you look how Unity or other engines handle this and implement it in FMOD?
