Labelled Parameters setup in UE4
I’m trying to implement a music system using labelled parameters in UE4.
Thing is, in blueprints, the set global parameter and set parameter nodes can only receive float values and no string values.
Is there a way to input string value to change a labelled parameter ? I’d like to avoid remaking my interactive music with float values only.
You can see the float values for your labeled parameters in the Edit Parameter window on the right for each label entry:
grafik
Use that values in blueprints :slight_smile:
I tried that but it didnt seem to work. I’ll try again when I get back to work ! Thanks for the answer.
Currently you can only set parameter values in game by float, not by string value.
Has this been resolved in current version for UE5? We were wondering the same thing just now and can’t seem to find an answer in the documentation.
Currently it is only accessible via code, I will bump the task for adding it to blueprints and see if we can get it added to an upcoming release.
Yes please, it appears that this was added to the Unity integration a little while ago?
Just bumping this again as it really does add a lot of work if one wants to maintain a clean structure while inserting new values (such as a soundtrack that uses Labeled values to select different regions, and you want to add a new section where it fits in the progression).
I’ve bumped the priority of this one again. Thanks.
