hello, Someone know the reason? fmod version is 2.01.11 , Android 11,level 30, unity version 2018.4.34f1
#00 pc 00000000000afeac /apex/com.android.runtime/lib64/bionic/libc.so (pthread_mutex_lock+8) [arm64-v8a::4995223f2954ed2746d96c2f1c7939a1]
#01 pc 00000000000c8e24 /data/app/~~k3zJ9P90TYrIj8XBmLoD6w==/com.tencent.xzj-o4j3tsVdY4uXM-7JIqbosA==/lib/arm64/libfmod.so [arm64-v8a::6900fdcc54e1627f82f1a0b10e8e8542]
java:
org.fmod.FMOD.access$000(FMOD.java:13)
org.fmod.FMOD$PluginBroadcastReceiver.onReceive(FMOD.java:137)
android.app.LoadedApk$ReceiverDispatcher$Args.lambda$getRunnable$0$LoadedApk$ReceiverDispatcher$Args(LoadedApk.java:1619)
android.app.-$$Lambda$LoadedApk$ReceiverDispatcher$Args$_BumDX2UKsnxLVrE6UJsJZkotuA.run(Unknown Source:2)
android.os.Handler.handleCallback(Handler.java:938)
android.os.Handler.dispatchMessage(Handler.java:99)
android.os.Looper.loop(Looper.java:257)
android.app.ActivityThread.main(ActivityThread.java:8209)
java.lang.reflect.Method.invoke(Native Method)
com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:626)
com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1015)
