Missing Event Browser in Unity
Hello everyone,
I’ve been getting this error in unity while trying to set an EventRefrence in the inspector after building.
Here’s the error:
NullReferenceException: Object reference not set to an instance of an object
FMODUnity.EventBrowser+TreeView+<>c.b__35_0 (FMODUnity.EditorEventRef e) (at Assets/Plugins/FMOD/src/Editor/EventBrowser.cs:264)
System.Linq.Enumerable+WhereSelectListIterator2[TSource,TResult].ToArray () (at <864870be861f4ce0a54a99d6c7a77a21>:0) System.Linq.Buffer1[TElement]…ctor (System.Collections.Generic.IEnumerable1[T] source) (at <864870be861f4ce0a54a99d6c7a77a21>:0) System.Linq.OrderedEnumerable1+d__3[TElement].MoveNext () (at <864870be861f4ce0a54a99d6c7a77a21>:0)
System.Linq.Enumerable.Any[TSource] (System.Collections.Generic.IEnumerable1[T] source) (at <864870be861f4ce0a54a99d6c7a77a21>:0) FMODUnity.EventBrowser+TreeView.CreateSubTree[T] (System.String rootName, System.String rootPath, System.Collections.Generic.IEnumerable1[T] sourceRecords, System.Func2[T,TResult] GetPath, System.Func3[T1,T2,TResult] MakeUniquePath) (at Assets/Plugins/FMOD/src/Editor/EventBrowser.cs:318)
FMODUnity.EventBrowser+TreeView.BuildRows (UnityEditor.IMGUI.Controls.TreeViewItem root) (at Assets/Plugins/FMOD/src/Editor/EventBrowser.cs:263)
UnityEditor.IMGUI.Controls.TreeView+TreeViewControlDataSource.FetchData () (at <1650f973f32045d6bc81eca6beea8ea9>:0)
UnityEditor.IMGUI.Controls.TreeViewDataSource.ReloadData () (at <1650f973f32045d6bc81eca6beea8ea9>:0)
UnityEditor.IMGUI.Controls.TreeView+TreeViewControlDataSource.ReloadData () (at <1650f973f32045d6bc81eca6beea8ea9>:0)
UnityEditor.IMGUI.Controls.TreeViewController.ReloadData () (at <1650f973f32045d6bc81eca6beea8ea9>:0)
UnityEditor.IMGUI.Controls.TreeView.Reload () (at <1650f973f32045d6bc81eca6beea8ea9>:0)
FMODUnity.EventBrowser.ReadEventCache () (at Assets/Plugins/FMOD/src/Editor/EventBrowser.cs:99)
FMODUnity.EventBrowser.BeginInspectorPopup (UnityEditor.SerializedProperty property, FMODUnity.EventBrowser+TypeFilter typeFilter) (at Assets/Plugins/FMOD/src/Editor/EventBrowser.cs:1600)
FMODUnity.EventBrowser.ChooseEvent (UnityEditor.SerializedProperty property) (at Assets/Plugins/FMOD/src/Editor/EventBrowser.cs:1564)
FMODUnity.EventReferenceDrawer.OnGUI (UnityEngine.Rect position, UnityEditor.SerializedProperty property, UnityEngine.GUIContent label) (at Assets/Plugins/FMOD/src/Editor/EventRefDrawer.cs:81)
UnityEditor.PropertyDrawer.OnGUISafe (UnityEngine.Rect position, UnityEditor.SerializedProperty property, UnityEngine.GUIContent label) (at <1650f973f32045d6bc81eca6beea8ea9>:0)
UnityEditor.PropertyHandler.OnGUI (UnityEngine.Rect position, UnityEditor.SerializedProperty property, UnityEngine.GUIContent label, System.Boolean includeChildren, UnityEngine.Rect visibleArea) (at <1650f973f32045d6bc81eca6beea8ea9>:0)
UnityEditor.GenericInspector.OnOptimizedInspectorGUI (UnityEngine.Rect contentRect) (at <1650f973f32045d6bc81eca6beea8ea9>:0)
UnityEditor.UIElements.InspectorElement+<>c__DisplayClass59_0.b__0 () (at :0)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr, Boolean&)
Here’s the thing. This happens only if I previously built FMOD since I opened the project. Before I build it, the event browser opens but, it’s missing the last two events I added in the project. Then again if I try to build I start getting the error every time I click on the search button for event references in the inspector.
I honestly have no idea why this is happening. I can’t find any other discussion that solves my specific problem at least. I tried reinstalling FMOD and I get the same error over and over again.
Any help would be much appreciated, thank you in advance!
Thank you for bringing this to our attention and sharing the logs. Just to confirm, when you mention building are you referring to building the banks? Can you confirm that you are seeing the bank refresh pop up in Unity when rebulding:
Could I also please get your FMOD Studio Version:
And the Unity Version:
Thank you
Ofcourse! Sorry about the late answer.
Yes, I am referring to the building of the FMOD banks and I am seeing the pop up.
Here is the rest of the info you asked for:
FMOD Studio version: 2.02.23
And here is the unity plugin version: 2.02.26
The unity version I am using is 2021.3.35f1
Thank you very much for the reply!
No worries, thank you for the information. What is your Source Type
And Bank Loading behavior?
Can you confirm that the Master.strings.bank is present in your Studio project build location:
