Plugins Greyed Out On Groups / Master Bus (2.03.02)
On FMOD Studio 2.03.02, it appears that certain plugins are now greyed out when you attempt to add them to a group / the master bus:
This is different than 2.03.01, where you’d be able to add the Resonance Audio Listener to the master bus. Is this intended behavior?
I am working on a plugin that should be placeable on both events and groups, but is greyed out like the Resonance plugins only on 2.03.2.
No, this is a bug. You should be able to add Resonance Audio Listener effects to buses.
It looks like this issue was introduced in FMOD Studio versions 2.02.23 and 2.03.02. In versions 2.03.00 and 2.03.01, and versions 2.02.22 and earlier, Resonance Audio Listener effects can be added to buses without problems.
I’ve added this issue to our bug tracker, so that it can be fixed in an upcoming release of FMOD Studio. In the mean time, you should be able to work around the issue by opening your project in FMOD Studio version 2.03.01, adding the Resonance Audio Listener effect to the bus of your choice, then saving and closing the project before opening it again in version 2.03.02.
Just to add a quicker solution to this…
  1. Load Resonance Audio Listener onto a master track of an event.
  2. Right click the plugin and select ‘Copy’
  3. Head to your group/bus and paste the plugin wherever you want it
This seems to work fine
