Popping when cutting off instruments
Hi folks,
Currently making an engine sound.
There’s a fair bit of popping going on (especially with bassy sounds) when cursor comes off instruments with Cut enabled which i can reduce by:
  • Slowing seek speed
  • Changing crossfade bezier shape
  • Changing zero crossing point and crossfades in Reaper
It helps but not entirety… i suppose popping is happening because it’s going from a value to 0 instantly.
Wondering if anyone has any tips, thanks!
here’s my issue, you can hear pops 2022 08 30 15 47 14 - YouTube
i think the issue is, I am not using autopitch, but manual pitch keyframes
i will switch to autopitch!
Happy to hear you found a solution and thank you for sharing. I will pass on your findings to our development team to look into further.
